Ubuntu 10.04 Startup problem
Posted 10 giu 2011, 21:21 CEST 0 Replies
As mentioned in previous threads
www.comsol.asia/community/forums/general/thread/7444/
and
www.comsol.com/community/forums/general/thread/18493/
I made the respective changes but I still get the error:
The program 'SWT' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 3115 error_code 9 request_code 136 minor_code 3)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
A small note is that
.comsol/v42/comsol.prefs
reverts back to the original file after giving me this error
i.e. the addition I made to comsol.prefs is not reflected in it.
graphics.rendering.2drend=swing
Hello Kalyana Sundaram Venkataraman
