COMSOL example model results do not match with Mathematical Model
Hi! I started to look into freq response analysis of a cantilever beam using COMSOL. Luckily COMSOL already has an example model "Model Library>> Structural mechanics module>>Dynamics and Vibrations>>rotating blade". While not changing anything in the model and with Omega=0 and Cloris =0, I get the following results
Resonance Freq1 = 84.36
Resonance Freq2 =528.84
Resonance Freq3 =949.31
Resonance Freq4 =1316.00
Resonance Freq5 =1481.41
Resonance Freq6 =2882.00
But Euler beam theory (options>>constants) gives me the following
Resonance Freq2 =528.66
Resonance Freq3 =1862.89
Resonance Freq4 =3650.55
Resonance Freq5 =6034.61
Resonance Freq6 =9064.89
Clearly the results do not match after 2nd natural/ resonance freq. I am quite sure that COMSOL example model cannot be wrong but there is something odd. Some elaboration would be appreciated
2 Replies Last Post 14 giu 2011, 08:17 GMT-4
Posted: 1 decade ago 14 giu 2011, 00:47 GMT-4
there are many tings that can change (but I would rather trust COMSOL for the given shape, material and loading you have defined)
Are you 100% sure you are exactly in the same dimension (2D/3D), same material, same shapes, same overall BC's ?
Hi there are many tings that can change (but I would rather trust COMSOL for the given shape, material and loading you have defined) Are you 100% sure you are exactly in the same dimension (2D/3D), same material, same shapes, same overall BC's ? -- Good luck Ivar
Posted: 1 decade ago 14 giu 2011, 08:17 GMT-4
You are comparing apples and oranges. The COMSOL model is a full 3D model, so it is expected that it would capture eigenfrequencies that a beam model would miss.
