2D geometry vs 3D geometry
hi people
I created a workplane out of a 3D geometry and then created a 2D object i.e. a circle, I understand that the 2D geometry ought to be embedded into the 3D one, but when I clicked on one of the physics (in the sense that I was about to assign sorta boundary conditions to the 2D geometry), I cannot see the embedded 2D geometry, not even as a boundary or domain or edge etc. Any clues that I can assign a boundary condition to the 2D geometry?
Many thanks!!
liwah
3 Replies Last Post 15 ago 2011, 08:53 GMT-4
Posted: 1 decade ago 22 giu 2011, 07:26 GMT-4
Hi Liwah,
I had a similar problem. The 2D object doesn't seem to be considered as a proper boundary or a line in the 3D environment.
In my case, I wanted to create a circle on a cylinder, so I did a plane and then I took the difference between the cylinder and the plane.
Please tell me if you found something else!
Guillermo
Hi Liwah, I had a similar problem. The 2D object doesn't seem to be considered as a proper boundary or a line in the 3D environment. In my case, I wanted to create a circle on a cylinder, so I did a plane and then I took the difference between the cylinder and the plane. Please tell me if you found something else! Guillermo
Posted: 1 decade ago 15 ago 2011, 07:43 GMT-4
what worked for me is,
1) create 2d object in work plane (centered at default 0,0,0 location)
2) do Geometry -> Transformed -> Copy,
a) deselect [ ] Keep input objects
b) translate Copy to correct location
3) assign properties to the Copy, and continue..
The work plane will remain in the build list, but disappear as a boundary.
How I *do* wish the "Embed" menu item from 3.5 would be reinstated..
Dave
Disclaimer: I am not an expert; there may be a better way :)
what worked for me is, 1) create 2d object in work plane (centered at default 0,0,0 location) 2) do Geometry -> Transformed -> Copy, a) deselect [ ] Keep input objects b) translate Copy to correct location 3) assign properties to the Copy, and continue.. The work plane will remain in the build list, but disappear as a boundary. How I *do* wish the "Embed" menu item from 3.5 would be reinstated.. Dave Disclaimer: I am not an expert; there may be a better way :)
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 15 ago 2011, 08:53 GMT-4
The "embedding" is implicit i V4, so if you, for example, create a circle in a work plane that coincides with the side of a block, the analyzed geometry includes the circle area as a separate boundary in the 3D model. You should not need to take any additional steps before proceeding to define your boundary conditions and so on.
Magnus Ringh, COMSOL
Hi, The "embedding" is implicit i V4, so if you, for example, create a circle in a work plane that coincides with the side of a block, the analyzed geometry includes the circle area as a separate boundary in the 3D model. You should not need to take any additional steps before proceeding to define your boundary conditions and so on. Best regards, Magnus Ringh, COMSOL
