Draw curves
I use Comsol 3.5 and I simulated the electrical field between 2 electrodes. Now I want to draw a curve (X=Distance between electrodes) (Y=the Electric field) or something like this. But I can not find any special tabs for drawing these kind of curves (x,y). can someone tell me what should I do?
2 Replies Last Post 24 giu 2011, 19:06 GMT-4
Posted: 1 decade ago 23 giu 2011, 17:54 GMT-4
If I understand what you are trying to do correctly, you want to parametrize your geometry and then plot a quantity that varies with the parameter vs the parameter. If that is the case, then consider upgrading to the current version, v4.2, which makes parametrizing a geometry quite easy. In v3.5, it is tedious work at best.
Posted: 1 decade ago 24 giu 2011, 19:06 GMT-4
Yes Jean. Thant's exactly what I want to do. It seems I should think about upgrading my version. I tried many ways but as you mentioned it is tedious work.
