Jeff Hiller
COMSOL Employee
1 lug 2011, 15:47 GMT-4
I know very little about vocal folds and their modeling, but Google Scholar finds a bunch of papers with the query string "vocal fold + COMSOL":
scholar.google.com/scholar?q=vocal+fold+%2B+COMSOL&hl=en&btnG=Search&as_sdt=1%2C22&as_sdtp=on
I hope it helps.
http://scholar.google.com/scholar?q=vocal+fold+%2B+COMSOL&hl=en&btnG=Search&as_sdt=1%2C22&as_sdtp=on
I hope it helps.
1 lug 2011, 16:04 GMT-4
Thank you for the reply. I am specifically looking for software that can analyze a biphasic elastic material dynamically. This has never been applied to vocal folds before. COMSOL has been used to analyze vocal folds before, but they were not modeled as a biphasic material, and that is what comes up in google scholar.
Jeff Hiller
COMSOL Employee
1 lug 2011, 16:56 GMT-4
I am clearly out of my range here, but what you describing sounds to me like it may be similar to the poroelastic modeling that's feasible with the Subsurface Flow Module (i.e. mechanical behavior of a porous saturated medium, including transients).
Can you say more about how you want the "biphasicity" of the material to affect the equations governing the mechanical model?
6 lug 2011, 18:10 GMT-4
We would like a poroviscoelastic biphasic model that is able to describe some or all of the following: liquid motion, solid stress fields, solid-liquid interaction, and continuity and momentum equations that describe momentum exchange between the liquid and solid components. I have included a short attachment with the equations describing our biphasic model.
Thank You,
Anton
Thank You,
Anton
7 lug 2011, 14:02 GMT-4
I'm currently working with a poroelastic model too. My model is a beam undergone a unconfined compression by a permanent load on the top side boundary, only the fluid is not viscous.
I used the 'equation based PDE' module with 3 variables: axial and radial displacements (for cylindrical system without shear stresses) and hydraulic pressure. For fitting the equations to this module, I rearranged the governing equations of poroelasticity so they depend only these 3 variables.
I don't know if there is a better way to do this with comsol.
8 lug 2011, 17:29 GMT-4
Thanks for the info. Is the compression you are modeling dynamic or quasi-static? The most important aspect in our model is that it has to be dynamic and poroelastic. Subsurface flow Module looks somewhat promising, and I will take a look at the equation based PDE Module too.
8 lug 2011, 18:59 GMT-4
I don't know what is dynamic in your model, but my model is time-dependent. It means that a permanent surface load generates time-dependent displacements of the tissue, thus a time-dependent pressure inside. However, the tissue parameters such as Lamé constants, permeability coefficient are constants except for the Young's modules which depend on the displacement rate at each instance.
In your case, if only the tissue parameters are time-dependent, you can use the 'Parametric' study for a static 'Physics'. if your equations has time derivative terms, a 'time-dependent' study will be inevitable. if only the frequency analysis interests you, it would be necessary to change the equations to frequency-domain, then the problem can be treated as static but with 'parametric' study.
I hope this could help.
11 lug 2011, 16:14 GMT-4
The Comsol support said that The 'earth science' module can also be used for this kind of problem.
