Internal Error In Geometry Composition
Posted 3 ago 2018, 08:00 GMT-4 Geometry Version 5.2 2 Replies
The below post is related to an archived discussion
Similar to what was said in the linked post above (which hase been closed), Lately I am spending around 70% of my time fighting the software because when building geometries the boolean operation (the last stage in building a geometry) fails to work.
The error occurs even when using only simple shapes that intersect at straigh angles (nothing complex like the intersection of doubly curved surfaces). The error message produced is not helpfull and its occurance is very inconsistent. This is the biggest issue I have had with the software, and the problem is still here after years and years! We have tried building geometries in an extarnal CAD program and importing, but this will lead to similar behaviour with unextpected/inconsistent errors popping up when the time comes to do the boolean operation (and finaly start the actual work).
This is a call to the software team to give this issue TOP PRIORITY. In my opinion more time should be given to fixing this issues instead of adding more modules, more features or changing them.
Please respond if you share this opinion, so the extend of the issue can be made clear to the developers. I know fellow workers share the same experience (and I suspect that there are more like us out there).
Kind Regards, Marten Nijhof
