How to set up scattering and/or E-Field by nanosphere in 2D axisymmetric model?
I've modeled some scattering and E-Field nanosphere simulations by 3D from mei theory with success, but was wondering if it would be possible to model the same geometry (sphere, radius, etc) in a 2D axisymmetric model?
I've tried this, but it seems I am getting a simplification for a cylindrical object (the simulation I made is attached below), not sphere. Any help would be greatly appreciated.
Eric Cutler
2 Replies Last Post 30 ago 2018, 10:49 GMT-4
Posted: 6 years ago 28 ago 2018, 18:59 GMT-4
Well, I haven't looked at your model, but one issue comes immediately to mind, based on your question: In most cases, for such an approach to work, your problem would need to be axi-symmetric not just in the geometry, but in the computed fields. Is it? If not, you will need to account for the asymmetry analytically, and very very carefully. If you can't do that, then you need to do a 3D treatment. This is more numerically intensive, but you can probably use two planes of symmetry to reduce the size. Good luck.
Posted: 6 years ago 30 ago 2018, 10:49 GMT-4
Hi Robert,
Thanks for the feedback, I believe I have it set up as to have it axi-symmetric in the computed fields. It seems the incident E-Field is induced along the center to make it axi-symmetric too.
However, in the future I do want to make complex shapes that are not axi-symmetric, so I'll keep your comments in mind when I reach that stage.
Regards, Eric Cutler
Hi Robert, Thanks for the feedback, I believe I have it set up as to have it axi-symmetric in the computed fields. It seems the incident E-Field is induced along the center to make it axi-symmetric too. However, in the future I do want to make complex shapes that are not axi-symmetric, so I'll keep your comments in mind when I reach that stage. Regards, Eric Cutler
