22 lug 2011, 08:36 GMT-4
What you have to do is integrate a boolean expression such as T>50[degC] (which is 1 if true and 0 otherwise) over the domain of interest (that "surface" you speak of).
There are two ways to achieve this. Either you simply integrate the expression in post-processing (Results -> Derived Values). Or, slightly more complicated but offering more flexibility, you first define an integration operator for the domain (under the Model -> Defintions node) and then evaluate that operator using a Global Expression in post-processing.
25 lug 2011, 04:25 GMT-4
Thanks John, you've helped me a lot :)
8 years ago
2 giu 2017, 05:19 GMT-4
Updated:
8 years ago
2 giu 2017, 05:34 GMT-4
Do you know by any change what will be the parameter to calculate this area? In my case I used:
if(T>Tvap, 2*dom,0) under the surface integral but the resulted area isn't what I would expected. Instead of dom what other variable is used for surface area calculation in Comsol 5.2a?
Thank you.
Edit:
I figured it out and it seems that the formula I used is right but please feel free to make any comments.
[QUOTE]
[/QUOTE]
Thank you.
Edit:
Walter Frei
COMSOL Employee
8 years ago
2 giu 2017, 10:26 GMT-4
You may also be interested in the timeint and timemax operators ( see section on Operators, Functions, and Constants in the COMSOL Multiphysics Reference Manual)
For example, you could plot:
timemax(0,30[s],T) which will show the maximum temperature that is achieved over the first 30 seconds.
or:
timeint(0,30[s],(T>400[K])) will compute and plot how long a particular region is held above 400K in the first 30 seconds.
or:
