COMSOL Automation
Posted 9 dic 2009, 14:52 GMT-5 0 Replies
I have some models whose data need further processing. I need to export values along a single line in a 3D model, but I may need to vary the line's position along y direction for ten times and export the data. So if I have 27 models, I need to do the same operation for 270 times, which is quite time-consuming task. So I just wonder if there are some automation scheme I may use like the VBA for MS Office? This may significantly increase the workflow speed.
Thank you,
Peng
Hello PENG LIAN
