Specify file name to import as a parameter
Hi there,
Is there a way to specify which DXF file to import as a polygon in a work plane, using a parameter?
I'm generating the structures I want to study using a (Python) script that exports them as DXF files. Typically, I vary some parameters to optimize the structures, so I'll end up with a folder filled with (slightly different) DXF files. Ideally, I would like to loop over the files in this folder using a COMSOL Parametric Sweep, for example by using the file name as a sweep parameter. Is this possible?
Thanks!
2 Replies Last Post 4 mar 2019, 17:01 GMT-5
François Mandias COMSOL Employee
Posted: 6 years ago 12 nov 2018, 07:02 GMT-5
Hi Jesse, I've sent you a private message.
Cheers, François
Hi Jesse, I've sent you a private message. Cheers, François
Posted: 5 years ago 4 mar 2019, 17:01 GMT-5
Hi Francois,
I have a similar situation in which I would like to parameterize the DXF import file. Can you share the solution you suggested to Jesse in the private correspondance?
Thanks, Chris
Hi Francois, I have a similar situation in which I would like to parameterize the DXF import file. Can you share the solution you suggested to Jesse in the private correspondance? Thanks, Chris
