Save solution after cancelation
Hello, I want to ask, if there is a way to get and save the solution when I cancel/abort the simulation by myself. Thanks in advance for your help.
Greetings, Kant
4 Replies Last Post 20 nov 2018, 10:17 GMT-5
Posted: 6 years ago 20 nov 2018, 07:09 GMT-5
Updated: 6 years ago 20 nov 2018, 07:10 GMT-5
If you click the hard cancel, i.e. the red cross icon on the frame, then the solution is lost.
If you click one of the Stop buttons in the Progress tab, then the solution is kept, but it may take some time until the solver stops.
Henrik
Henrik Sönnerlind
COMSOL
Hi, If you click the hard cancel, i.e. the red cross icon on the frame, then the solution is lost. If you click one of the Stop buttons in the Progress tab, then the solution is kept, but it may take some time until the solver stops. Regards, Henrik
Posted: 6 years ago 20 nov 2018, 07:19 GMT-5
Thanks for the fast answer, Henrik.
Posted: 6 years ago 20 nov 2018, 08:16 GMT-5
Hi Henrik,
this works in the model builder. Is there an option in an application in the meanwhile?
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Henrik, this works in the model builder. Is there an option in an application in the meanwhile? Cheers Edgar
Posted: 6 years ago 20 nov 2018, 10:17 GMT-5
Hi Edgar,
Currently, only a hard Cancel is available in applications.
Being able to do something softer could definitely be useful, and the request has been noted.
Henrik
Henrik Sönnerlind
COMSOL
Hi Edgar, Currently, only a hard Cancel is available in applications. Being able to do something softer could definitely be useful, and the request has been noted. Regards, Henrik
