constraints in structural module
I try to apply constrint in structural module
I make rectengular shaped model in 2D and applied the prescribed displacement.
and I want to stop when the stress or reaction force reached specific value.
how can I impose the constraints?
thankt you
1 Reply Last Post 23 nov 2018, 11:14 GMT-5
Posted: 6 years ago 23 nov 2018, 11:14 GMT-5
If you want to terminate an analysis once a certain value is reached, you can add a Stop Condition node under the Parametric node in the solver sequence. As stop expression you can use any global value, for example computed by a max or integration operator.
Henrik
Henrik Sönnerlind
COMSOL
Hi, If you want to terminate an analysis once a certain value is reached, you can add a **Stop Condition** node under the **Parametric** node in the solver sequence. As stop expression you can use any global value, for example computed by a max or integration operator. Regards, Henrik
