using DerivedValues - Surface Integration as objective function
Hello!
I have created a model, which solves a structural problem. Geometry in this problem depends on parameter b. I'm calculating maximum von Mises stress in a region using Derived Values->Surface Maximum. This part works fine.
Next I want to set up optimization problem and find value of parameter b minimizing maximum mises stress. I added optimization node, but don't know how to set Maximum Mises Stress as Objective Function. I can't find it in the list "Replace Expression" and don't know which name i can use for this if any exist.
Could anyone please help me with this? How can I set Maximum mises stress as objective function?
Thank you!
4 Replies Last Post 7 dic 2018, 10:42 GMT-5
Posted: 6 years ago 6 dic 2018, 13:51 GMT-5
Hi Sergey,
the derived values are only available for post processing. But you can find the maximum during solving by using a coupling operator. You can find that under 'Component -> Definitions -> Component Couplings'.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Sergey, the derived values are only available for post processing. But you can find the maximum during solving by using a coupling operator. You can find that under 'Component -> Definitions -> Component Couplings'. Cheers Edgar
Posted: 6 years ago 6 dic 2018, 18:37 GMT-5
Hi Edgar! Unfortunately I can't see "Component Couplings" under Component>Definitions. There are only "Material Functions" and "Variables" there.
Is any way I can turn on the Components Coupling?
Thanks!
Hi Edgar! Unfortunately I can't see "Component Couplings" under Component>Definitions. There are only "Material Functions" and "Variables" there. Is any way I can turn on the Components Coupling? Thanks!
Posted: 6 years ago 7 dic 2018, 02:27 GMT-5
You have to right-click on the 'Definitions'. I am not sure what exactly the naming in 5.2a was, but don't think it was different.
Edgar J. Kaiser
www.emphys.com
Posted: 6 years ago 7 dic 2018, 10:42 GMT-5
Edgar, I found it, it seems to work now. Thank you so much for your help!
Best regards, Sergey
Edgar, I found it, it seems to work now. Thank you so much for your help! Best regards, Sergey
