Coefficient form PDE, Zero Flux BC
Can I ask if there is any way in Coefficient Form PDE, to cancel zero flux BC and apply Periodic Boundary Condition?
My file is attached. I really urgently need someone to help me out with this.
Thanks in advance,
Kartiek
3 Replies Last Post 31 lug 2015, 10:11 GMT-4
Posted: 1 decade ago 16 ago 2011, 21:55 GMT-4
Is there really no way to apply the periodic boundary conditions without having the zero flux BC ?
At least, in the RF module applying Periodic Boundary Conditions overrides the other BC on that boundary. But not so in the PDE interface modes. Can this be corrected for?
Kartiek.
Is there really no way to apply the periodic boundary conditions without having the zero flux BC ? At least, in the RF module applying Periodic Boundary Conditions overrides the other BC on that boundary. But not so in the PDE interface modes. Can this be corrected for? Kartiek.
Posted: 1 decade ago 10 gen 2013, 06:52 GMT-5
Hi Kartiek,
I also confronted with the same problem as you did. When using the periodic condition in the Weak form PDE Module, I found the zero flux setting is defined by default, and cannot be cancelled when setting the periodic boundary condition.
I want to ask that whether you have solved such a problem.
Many thanks for your reply.
Jia
Hi Kartiek, I also confronted with the same problem as you did. When using the periodic condition in the Weak form PDE Module, I found the zero flux setting is defined by default, and cannot be cancelled when setting the periodic boundary condition. I want to ask that whether you have solved such a problem. Many thanks for your reply. Best regards, Jia
Posted: 9 years ago 31 lug 2015, 10:11 GMT-4
Hi jia
Have you solved the problem of zero flux BC?
I recently counter the same problem using weak form pde.
Please let me know if you've solved it
Wenlong
Hi jia Have you solved the problem of zero flux BC? I recently counter the same problem using weak form pde. Please let me know if you've solved it Best, Wenlong
