corona discharge
Hello everybody,
I am new in comsol and I try to create a numerical model in comsol to simulate the corona discharge between a very thin tungsten wire (20 micrometer diameter) and a grounded aluminium plate. The two elements were placed in air. Which model should I use ? (PDE, EMES, Electrostatics generalized.....?)
Thank you!
2 Replies Last Post 30 ago 2011, 13:25 GMT-4
Posted: 1 decade ago 30 ago 2011, 09:18 GMT-4
Marius,
I presume the plasma module should fit best. However, I don't have it so I cannot give practical advice.
Cheers
Edgar
Marius, I presume the plasma module should fit best. However, I don't have it so I cannot give practical advice. Cheers Edgar
Posted: 1 decade ago 30 ago 2011, 13:25 GMT-4
If been trying to model corona discharges with comsol too. My advice is that you should start with the tutorial models on the DC plasma to get to know how it works.
To solve a corona discharge the module to be used is the plasma. However, you will face several problems if you have planned to solve an atmospheric pressure discharge.
Good luck!
JH
Hi, If been trying to model corona discharges with comsol too. My advice is that you should start with the tutorial models on the DC plasma to get to know how it works. To solve a corona discharge the module to be used is the plasma. However, you will face several problems if you have planned to solve an atmospheric pressure discharge. Good luck! JH
