Comments on every node
I suggest having a comments box on every node so I can better explain the model. Now it is only available on root node.
1 Reply Last Post 2 set 2011, 15:05 GMT-4
Posted: 1 decade ago 2 set 2011, 15:05 GMT-4
you have a comment box for all nodes check the "sub-node right-click properties"
Hi you have a comment box for all nodes check the "sub-node right-click properties" -- Good luck Ivar
