7 set 2011, 10:48 GMT-4
I do not suppose its possible, you could try to dump it as a *.m file and tweak it to be 3.3 compatible. Hence the importance to get all partners to use the SAME version
16 dic 2011, 08:43 GMT-5
Ihave a similar problem but with version 4.2a. Is it possible to convert the file from 4.2a into 4.2?
Thank you!
Kalin
Thank you!
Kalin
16 dic 2011, 15:43 GMT-5
I do not believe "down" converting is possible, most programmes on the market only allows to read into newer versions. To be sure you must check with "support"
10 dic 2013, 07:52 GMT-5
now I have the same problem but I have Comsol 4.3b and I need to save it in Comsol 4.3.
It´s possible?
So, how I can convert my model in a 4.3 version ?
Thank you in advanced
Joaquim
It´s possible?
Joaquim
Gunnar Andersson
COMSOL Employee
11 dic 2013, 04:37 GMT-5
It´s possible?
It isn't possible to open a model saved in 4.3b in 4.3. The workaround proposed earlier in the thread - going via an exported .java- or .m-file - might work, but there is no guarantee.
[QUOTE]
It´s possible?
[/QUOTE]
