Edgar J. Kaiser
Certified Consultant
6 years ago
19 dic 2018, 05:14 GMT-5
in the context of AC/DC the coaxial cable can be replaced by the equivalent circuit. This is a series inductor, series resistor and parallel capacitors. The coaxial cable must be much shorter than any wavelength in the model.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
6 years ago
20 dic 2018, 20:00 GMT-5
Cheers
Edgar
Thanks for your comment Mr. J. Kaiser,
the approach proposed by you is very rough approximation for my task, since I investigate the effect of coaxial cable length.
Regards
Shant
Sh.Arakelyan
>Hi,
>Cheers
>Edgar
Regards
Shant
Edgar J. Kaiser
6 years ago
21 dic 2018, 04:45 GMT-5
I would say, it depends.
The equivalent parameters depend on the length, e.g. the capacitance for a typical 50 Ohm cable is 90 pF/m. The equivalent circuit can be good enough as long as the wavelength of the signal is much larger than the cable length.
If the cable length gets longer than lambda/10 (this limit depends on the accuracy requirements) and you have to take transmission line effects into account you need a different approach.
Edgar J. Kaiser
www.emphys.com
Dave Greve
6 years ago
21 dic 2018, 14:10 GMT-5
Modeling the coaxial cable with several lumps per wavelength will provide a good approximation. For "several"- four is enough, eight better, more probably not necessary. Most accurate will be to use T or pi sections.
D.W. Greve
DWGreve Consulting
D.W. Greve
DWGreve Consulting
6 years ago
26 dic 2018, 21:04 GMT-5
Updated:
6 years ago
27 dic 2018, 02:00 GMT-5
Thanks a lot, for your valuable comments.
Sh.Arakelyan
