How to compile external model coded by C language through Visual Studio 2017?
Dear all:
The User's Guide said "Start Visual Studio 2017>Visual Studio Tools>VC>x64 Native Tools Command Prompt for VS 2017 from the Windows Start menu. " However, I didn't find the corresponding buttons in Visual Studio 2017. Does anyone have experience to deal with the compilation issues?
Thank you for your help.
Yu
Yu Zhang
2 Replies Last Post 4 gen 2019, 09:26 GMT-5
Posted: 6 years ago 4 gen 2019, 02:11 GMT-5
It sounds as if you try to start the x64 Native Tools Command Prompt for VS 2017 from within Visual Studio 2017. You should instead start it from the start menu - see the attached image.
Posted: 6 years ago 4 gen 2019, 09:26 GMT-5
Hi, Gunnar Andersson:
I found it! Thank you so much for your valuble reply.
However, I encountered a confusion when trying to compile a self-defined model which contains the utility functions. In the users' Guide, the third step is to input "link /OUT:ext.dll /DLL ext.obj
C:\Program Files\COMSOL\COMSOL54\Multiphysics\data\extmat\win64\csextutils.lib"
into the command line. I found the .dll file has already created after only inputing the first line in the quote above. So I am wondering what is functionality of the file path in the second line. Is it correct if we neglect it? And should I input contents in the quote in one line or two lines?
Thank you so much for your time and help.
Yu
Yu Zhang
Hi, Gunnar Andersson: I found it! Thank you so much for your valuble reply. However, I encountered a confusion when trying to compile a self-defined model which contains the utility functions. In the users' Guide, the third step is to input "link /OUT:ext.dll /DLL ext.obj C:\Program Files\COMSOL\COMSOL54\Multiphysics\data\extmat\win64\csextutils.lib" into the command line. I found the .dll file has already created after only inputing the first line in the quote above. So I am wondering what is functionality of the file path in the second line. Is it correct if we neglect it? And should I input contents in the quote in one line or two lines? Thank you so much for your time and help. Yu
