COMSOL with MATLAB - 'colortablerev' doesn't work
I am working with “COMSOL 4.2 with MATLAB” and I want to plot the mesh quality. This works quite fine. But if I try to reverse the colors with the MATLAB command:
model.result('pg1').feature('surf1').set('colortablerev', 'on');
nothing happens, the colors stay as they are. If I do the model in COMSOL (without MATLAB) I can reverse the color (Reverse_test.mph). But if I save it as an m-file (Reverse_test.m) and run this in MATLAB reverse of the color doesn’t work. For this compare the colors of the graph of the .mph file and the .m, which should be the same.
How can I get this working?
Thanks in advance for your help
Simon
2 Replies Last Post 27 feb 2012, 08:21 GMT-5
Hello Simon Bühler
Posted: 1 decade ago 27 feb 2012, 08:19 GMT-5
I have the same problem, did you allready find a solution?
Tessa
Hi, I have the same problem, did you allready find a solution? Tessa
Posted: 1 decade ago 27 feb 2012, 08:21 GMT-5
No sorry, I gave up (and I didn't retry in later versions)
