building a magnetic field using a coil
hi,
I am new in comsol so i need a little bit of help to get started,
i need to generate a magnetic field using a coil where i can change the properties of it ( how many turns , the current that is flowing , etc..)
if anyone could help me would be great
thanks
1 Reply Last Post 22 set 2011, 14:16 GMT-4
Posted: 1 decade ago 22 set 2011, 14:16 GMT-4
for that you use typically a parametric sweep of the"continuation" type (in v4), basically if the surface of the coil remains (no volume changes) then adding coil turns basically multiplies the average coil section curent by "N"
Hi for that you use typically a parametric sweep of the"continuation" type (in v4), basically if the surface of the coil remains (no volume changes) then adding coil turns basically multiplies the average coil section curent by "N" -- Good luck Ivar
