6 years ago
6 feb 2019, 08:05 GMT-5
Updated:
6 years ago
6 feb 2019, 08:06 GMT-5
probably you can use FSI (fluid structure interaction) and 2 phase flow
probably the best way to start is to do some tutorials first:
https://www.comsol.com/model/inkjet-nozzle-8212-level-set-method-1445
https://www.comsol.com/model/two-phase-flow-with-fluid-structure-interaction-fsi-in-3d-4515
hope this helps
hope this helps
6 years ago
7 feb 2019, 08:13 GMT-5
Thank you for your answer
the problem that i face that i can't use the surfac etension for the fluid module to intertact with the solid in the structure mechanics module
because the surface tension can be applied only to fluid-fluid interface
while i have to add the viscoelastic properties through the solid mechanics module
