Edgar J. Kaiser
Certified Consultant
6 years ago
12 mar 2019, 06:44 GMT-4
Sujoy,
for the dynamic analysis all domains need to have a small electrical conductivity in mf, say 1 S/m. Maybe it can be even lower, you need to try.
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Sujoy,
Edgar
6 years ago
13 mar 2019, 07:46 GMT-4
Hello Edger,
I have tried with small conductivity but still not running the simulation. Could you please take a look to my simulation file which is attached ?
Thanking you
Sincerely
Sujoy
Hello Edger,
Thanking you
Sincerely
Sujoy
Edgar J. Kaiser
6 years ago
13 mar 2019, 07:51 GMT-4
I did test it. I applied 1 S/m to air and to the piezoelectric domain and it solved.
Edgar J. Kaiser
www.emphys.com
6 years ago
14 mar 2019, 02:02 GMT-4
Hello Edger,
Now it works. Its a great help for me. I am absolutly thankful to you. Though, simulation is taken much more time. Is there any way to redue it?
Looking forward for your kind reply.
Thanking you
Sujoy
Hello Edger,
Thanking you
Sujoy
Edgar J. Kaiser
6 years ago
14 mar 2019, 05:36 GMT-4
Updated:
6 years ago
There may be a couple of ways:
* Reduce the size of the model
Find out if the mesh can be coarser
Use lower order discretization
Try different direct and iterative solvers
Optimization can be tedious.
Edgar J. Kaiser
www.emphys.com
* Find out if the mesh can be coarser
* Use lower order discretization
* Try different direct and iterative solvers
6 years ago
14 mar 2019, 06:00 GMT-4
Thanks a lot Edger.
6 years ago
3 apr 2019, 09:24 GMT-4
Hello Edgar,
Hope everything is going well. Currently, I am facing a problem regarding the aforementioned problem. Though, it was solved for lower frequency region but when I am trying to solve with higher frequency region such as, 10 kHz, it is not solving and returned the following massages:
Maximum number of segregated iterations reached.
Not all parameter steps returned.
Could you please help me in this regard?
Thanking you
Sincerely
Sujoy
Hello Edgar,
Thanking you
Sincerely
Sujoy
6 years ago
20 mag 2019, 07:53 GMT-4
Hello Sujoy,
Have you been able to sort out the above problem of not being able to simulate in higher frequency range...??
Hello Sujoy,
6 years ago
20 mag 2019, 08:03 GMT-4
Hello Sir/Madam,
No, till now it is not solved.
Hello Sir/Madam,
