Issues at connecting one coarser mesh and an extremely thin mesh
Posted 5 apr 2019, 09:27 GMT-4 Low-Frequency Electromagnetics, Mesh Version 5.3a 3 Replies
Hi everyone,
Here is my problem, I got a really thin (1mm) frame (and 1.5mx0.5m) inside a big box (2mx2mx1m) and I want to have an extremelly fine mesh in the frame and a coarser one outside. Inside the frame I want exactly 10 layers of prisms, the thickness of each layer is therefore 0.1mm. Please look at the fille attached !
I first tried to use a surface mesh (free triangular mesh) on one face of the frame and swept it through the frame with a distribution of 10 layers, the remaining domains were meshed using free tetrahedral with a coarser mesh. But unfortunately I had some many errors saying that the boundaries of the two meshes couldn't be connected or that there was an error in the meshing domain...
Then I did exactly the same thing but using the boundary layer feature on the frame with 10 layers of 0.1mm and the boundaries being only one face (I also did 5 layers with the two faces) and I got the same kind of error.
Initially I wanted to mesh so thin in the frame to observe the skin effect (I'm working at 85kHz with conducitivites up to 10^7 S/m)...
Does anyone know how to do this ?
Cheers !
