Hello Yun He
Jeff Hiller
COMSOL Employee
9 years ago
4 dic 2015, 10:42 GMT-5
Hello Yun,
These days, the lofting capability is available without any programming necessary, see
www.comsol.com/design-module
Hello Yun,
These days, the lofting capability is available without any programming necessary, see http://www.comsol.com/design-module
8 years ago
13 feb 2016, 19:20 GMT-5
Hi Jeff,
I would like to generate 3D CAD from multiple layers MRI images in Comsol. I am using coordinates manually and then export to in to Comsol. While I did that I can not make lofting , I think , because images coordinates vary (x and y value vary). I have two questions
Firstly, Is there any simple way to have MRI images coordinates in Matlab?
Secondly, Do you have any recommendations about lofting problem as mentioned?
Any rec commendations would be appreciated. Many Thanks in advance
Best Regards
Enver Salkim
Hi Jeff,
Best Regards
Enver Salkim
Lorant Olasz
COMSOL Employee
8 years ago
15 feb 2016, 05:55 GMT-5
Hi Enver,
Perhaps the function mphimage2geom that comes with LiveLink for MATLAB could be of some help. It can be used to convert images into geometry, will output either interpolation curves or polygons.
Lorant
Hi Enver,
Lorant
Jeff Hiller
COMSOL Employee
8 years ago
16 feb 2016, 08:48 GMT-5
Hello Enver,
I don't believe I understand your question. Please contact our technical support team (support@comsol.com) should you still be facing difficulties.
Hello Enver,
