Error message: Failed to find consistent initial values. Singular matrix.
hey peeps
I keep receiving this error message:
============== error message ==============
Singular matrix
There are 19924 void equations (empty rows in matrix) for the variable mod1.p dl
at coordinates: (405321,5.86245e+006,-4243), (405321,5.86281e+006,-4098), (405321,5.86256e+006,-4193.33), (405321,5.86281e+006,-4243), (405321,5.86271e+006,-4148.67), ...
and similarly for the degrees of freedom (empty columns in matrix)
=========== end of error message ============
I went throught all relecant discussions in the forum but to no avail.
I have four 2D Bézier polygons (rectangles) and two 3D Bézier polygons (tubes) integrated within the 3D (extruded) block. I assigned Darcy's Law (Darcy's Law Material Model and Storage Material Model, (maybe) fracture flow and mass flux as well).
Meshing goes well - disable Darcy's Law, the simulation went well with good postprocessed GUI of mesh size and mesh quality.
Anything I might have missed out?
many thanks in advance!!!!!!!!!!!!!
regards
Liwah
2 Replies Last Post 2 nov 2011, 11:29 GMT-4
Posted: 1 decade ago 2 nov 2011, 11:08 GMT-4
For me it sounds like you are missing a boundary conditions, your ODE are not enough defined, check if all physics have consistent BC's
Hi For me it sounds like you are missing a boundary conditions, your ODE are not enough defined, check if all physics have consistent BC's -- Good luck Ivar
Posted: 1 decade ago 2 nov 2011, 11:29 GMT-4
Hi Ivar
many thanks!
yet, I did define BC for all geometries i.e. Storage Material Model for each of them, but to no avail.
you talked about 'consistent BC', how to make sure a consistency? I mean, anywhere to check that?
again, many thanks for your time!!
regards
Liwah
Hi Ivar many thanks! yet, I did define BC for all geometries i.e. Storage Material Model for each of them, but to no avail. you talked about 'consistent BC', how to make sure a consistency? I mean, anywhere to check that? again, many thanks for your time!! regards Liwah
