Steady-Time
Is there any simple way to identify the time that solution reaches steady state,*** " in particular in Livelink-Matlab"***
For instance, time-dependent fluid flow through a simple Y- junction needs ("t"-seconds) to reach its steady state. I'm going to find that specific "t" !
In addition, Is it possible to stop solving when solver reaches that particular "t"?
1 Reply Last Post 26 mag 2019, 15:54 GMT-4
Posted: 6 years ago 26 mag 2019, 15:54 GMT-4
You should be able to do that using Stop events. You can find more info by reading the Stop Condition section of the Studies and Solvers chapter of the documentation.
You will have to define for yourself what is the right criterion to qualify steady-state conditions, as this is problem dependent. Usually it would involve following the progression over time of some key output quantities.
Hi, You should be able to do that using **Stop events**. You can find more info by reading the _Stop Condition_ section of the **Studies and Solvers** chapter of the documentation. You will have to define for yourself what is the right criterion to qualify steady-state conditions, as this is problem dependent. Usually it would involve following the progression over time of some key output quantities.
