Materials Overlapping
Hi evryone. I'm new in comsol. I'm a student of master degree .. option Physics and radiation technologies. I want to simulate the thermal stress of fuel rod in triga nuclear reactor. I have a little problem with materials overlapping in the red cercles (image attached). its dosen't make sense becauce those solid materials are tough .. I want to simulate the thermal stress in those materials and I have a helium gas between them. so I need your help. if something I should know please tell me. https://imgur.com/a/5kAlSNr
3 Replies Last Post 29 mag 2019, 08:23 GMT-4
Posted: 6 years ago 27 mag 2019, 19:06 GMT-4
Are you sure you have set the scaling factor in the deformation plot correctly? By default it may be set to automatic scaling which may result in a high value just to make small deformations visible. Set it to 1 for real deformation.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Are you sure you have set the scaling factor in the deformation plot correctly? By default it may be set to automatic scaling which may result in a high value just to make small deformations visible. Set it to 1 for real deformation. Cheers Edgar
Posted: 6 years ago 28 mag 2019, 06:41 GMT-4
Thanks sir Edgar , I already had the same problem but after I set the scaling factor to 1 it's work for me .
Posted: 6 years ago 29 mag 2019, 08:23 GMT-4
Thank you Edgar J. Kaiser. It's work
