Multi-stack piezoelectric device simulation
I have a thin layer of piezoelectric material sandwiched between relatively thin film of two distinct metals. I am experiencing few problems while setting up the simulation.
First, the material properties for metals require coupling matrix even though they are not piezoelectric materials.
Second, comsol prefers stress-charge form parameters. How do I change this setting to strain-charge form so, I won't have to change elasticity to compliance matirx and d-matrix to e-matrix?
And last, how do I know whether the relative permittivity on material datasheet is given at constant stress or constant strain?
Will really appreciate your time while answering any or all of my queries. Thank you in advance!
2 Replies Last Post 4 giu 2019, 02:06 GMT-4
Posted: 6 years ago 3 giu 2019, 11:29 GMT-4
Updated: 6 years ago 3 giu 2019, 11:29 GMT-4
You need to specify that the metals are linear elastic materials under the Solid Mechanics node.
Stress-charge is the default, not a preference. Select strain-charge under the settings for the Piezoelectric Materials node.
If the datasheet doesn't say, you will have to consult the manufacturer.
D.W. Greve
> First, the material properties for metals require coupling matrix even though they are not piezoelectric materials. You need to specify that the metals are linear elastic materials under the Solid Mechanics node. > Second, comsol prefers stress-charge form parameters. How do I change this setting to strain-charge form so, I won't have to change elasticity to compliance matirx and d-matrix to e-matrix? Stress-charge is the default, not a preference. Select strain-charge under the settings for the Piezoelectric Materials node. > And last, how do I know whether the relative permittivity on material datasheet is given at constant stress or constant strain? If the datasheet doesn't say, you will have to consult the manufacturer. D.W. Greve
Posted: 6 years ago 4 giu 2019, 02:06 GMT-4
Updated: 6 years ago 4 giu 2019, 08:58 GMT-4
Thank you, Dave!
Thank you, Dave!
