Attempt to evaluate negative power of zero error
Posted 6 giu 2019, 11:12 GMT-4 3 Replies
I am working on a COMSOL model of 2D axisymmetric packed bed for studying breakthrough profiles of gases. I have defined all my Overall balance, component balance, Ergun's equation and LDF model equation using Mathematical General form PDE model. I am facing the following error when I used the valve equation (w0) as a Constraint (w - w0) at the outlet of my bed, where w is the velocity in z direction. {Note:My model converged and gave the output when my constraint term was just w, meaning outlet of the bed is closed}
Feature: Time-Dependent Solver 1 (sol2/t1) Attempt to evaluate negative power of zero. - Function: ^ Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.b@VDN$comp1.p - Defined as: comp1.y((comp1.p2)(0.5(((comp1.p^2)-(P0^2))^(-0.5)))) Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.w0@VDN$comp1.p - Defined as: ((((TPstd)comp1.x)(comp1.y((comp1.p2)(0.5(((comp1.p^2)-(P0^2))^(-0.5))))))(1/(((comp1.peb0)A)Tstd)))+((Tstd(eb0A))((-(((TPstd)comp1.x)comp1.b))/((((comp1.peb0)A)Tstd)^2))) Failed to evaluate expression. - Expression: d(comp1.w-comp1.w0,comp1.p) Failed to evaluate Jacobian of expression. - Expression: comp1.w-comp1.w0
Questions:
1) How to define Modulus of a term and will that help to solve this problem? 2) What are the ways to solve this error, is there some kind of time stepping or meshing corrections to be made? Please suggest. Thanks
