How to use external current density in racetrack coil
Hi all,
I need to analyze Electromagnetic force of racetrack coil with time dependent. To make this model, I use external current density. It has been confirmed that the external current density can be properly analyzed by time dependent analysis of circular coil. By using like those formula. Ix = I0-y/sqrt(x^2 + y^2), Iy = I0x/sqrt(x^2 + y^2), Iz=0
Now I try to analyze racetrack coil using external current density but I can't. I attached the file. Please give me your help and advice.
Thank you
4 Replies Last Post 12 lug 2019, 03:38 GMT-4
Nirmal Paudel Tribhuvan University/Electrical Engineering
Posted: 6 years ago 10 lug 2019, 16:22 GMT-4
Updated: 6 years ago 10 lug 2019, 16:22 GMT-4
Why don't you try using the Solid Conductor using the Coil feature to model the solid piece and compute the Lorentz Force?
BR/Nirmal
Hi, Why don't you try using the Solid Conductor using the Coil feature to model the solid piece and compute the Lorentz Force? BR/Nirmal
Posted: 6 years ago 11 lug 2019, 01:51 GMT-4
Updated: 6 years ago 11 lug 2019, 01:49 GMT-4
Dear Nirmal,
Thank you for your reply. I want to use the Coil future but it cannot be used in time dependent.
Dear Nirmal, Thank you for your reply. I want to use the Coil future but it cannot be used in time dependent.
Cesare Tozzo COMSOL Employee
Posted: 6 years ago 11 lug 2019, 10:50 GMT-4
Updated: 6 years ago 11 lug 2019, 10:49 GMT-4
Are you sure it is a single bulk conductor? If it is a bobbin (or if it is a bulk but you can assume constant resistivity as the pulse is slow... as could seem from your case given a fast look to parameters if it is not a multiturn) you can use multiturn. Transient 3D, current fed works out of the box for multiturn. This will include inductive effect averaged on the coil, but not local skin depth.
Have you already sent the model to support? If not, do it as we could help you as there is a couple of extra tricks for single turn, that you can use for current feeding time domain single turn conductor.
Cite a few. 1) add a voltage feed and se the voltage so to constrint current (in easy cases this is easy and works) 2) mix electric currents and magnetic fields as it is demoed in second part of https://www.comsol.com/model/rotating-machinery-3d-tutorial-10437 3) solution as https://www.comsol.com/model/geometry-optimization-of-a-3d-complex-shaped-coil-for-induction-heating-58051 where the feeding is put via a discontinuity on a "Magnetic Fields No Current" physics
Cesare
Are you sure it is a single bulk conductor? If it is a bobbin (or if it is a bulk but you can assume constant resistivity as the pulse is slow... as could seem from your case given a fast look to parameters if it is not a multiturn) you can use multiturn. Transient 3D, current fed works out of the box for multiturn. This will include inductive effect averaged on the coil, but not local skin depth. Have you already sent the model to support? If not, do it as we could help you as there is a couple of extra tricks for single turn, that you can use for current feeding time domain single turn conductor. Cite a few. 1) add a voltage feed and se the voltage so to constrint current (in easy cases this is easy and works) 2) mix electric currents and magnetic fields as it is demoed in second part of https://www.comsol.com/model/rotating-machinery-3d-tutorial-10437 3) solution as https://www.comsol.com/model/geometry-optimization-of-a-3d-complex-shaped-coil-for-induction-heating-58051 where the feeding is put via a discontinuity on a "Magnetic Fields No Current" physics Good luck Cesare
Posted: 6 years ago 12 lug 2019, 03:38 GMT-4
Updated: 6 years ago 12 lug 2019, 03:38 GMT-4
Dear Cesare,
Thank you for your answer, Cesare. I really appreciate your kind support. My coil shape is like a bobbin. I can use the multiturn in the Coil feature with time dependent but I can't solve it yet.
I'm goin to read those and try a little more. If I can't solve it, I will send the model to support and ask your help.
Thanks!!
Dear Cesare, Thank you for your answer, Cesare. I really appreciate your kind support. My coil shape is like a bobbin. I can use the multiturn in the Coil feature with time dependent but I can't solve it yet. I'm goin to read those and try a little more. If I can't solve it, I will send the model to support and ask your help. Thanks!!
