modelling of this mathematical equation
Posted 12 nov 2011, 23:05 GMT-5 Studies & Solvers Version 4.2a 10 Replies
dT/dt=k1/b(k2x-T(1+k2/k1)+A+bdx/dt).
in this T is the input i.e force and x is the elongation i.e output...rest all are constants.i was trying implementing this equation as ODE .
the right side of your equation will be the source term f, see the documentation.
Have you implemented your equation in COMSOL sussessfully?
Thanks.
no its showing error everytime as time dependent solver....unknown function.....but i have mentioned each and every parameter.i think i am missing some step.can u plz guide.
details
i need to calculate x that is elongation produced in the muscle wrt force applied.i have used cylindrical geometry and meshed .materials i have mentioned is of viscoelastic material.then i m using coefficient form of PDE .
In the coefficient form PDE interface documentation, u is the dependent variable. Have you set up your equation in a way that your T is the dependent variable u in the doc?
You have to write your equation in a way that your dependent variable X is the u in the documentation. The terms with T will be in the source term f of the documentation.
COMSOL Multiphysics User's Guide
Chapter 15: Equation-Based Modeling
Section: Coefficient Form PDE
Suggested Content
- BLOG Implementing a Damage Evolution Law for a Hyperelastic Material
- FORUM Adding a simple particle surface adsorption residence time to the mathematical particle tracing module (pt)
- KNOWLEDGE BASE Avoiding Negative Concentrations
- KNOWLEDGE BASE Computing Time and Space Integrals
- BLOG COMSOL Conference 2015 Grenoble Award Winners
