Surface charge density Vs. Capacitance
Posted 14 nov 2011, 11:00 GMT-5 Low-Frequency Electromagnetics Version 4.2a 3 Replies
Hello!
I have a problem with the solution of a very simple problem in the AC/DC-Electrostatics-Stationary modul (2D)
2 circles in a certain distance. A square box around as far boundary.
One circle is set to 1V via the Terminal interface the other is set to ground (dirichlet boundary conditions).
The boundary of the box is set to Zero Charge (for simulating Neumann boundary conditions).
After I evaluate the capacitance ("Global Evaluation") and a "Line Integration" for the surface charge density (es.nD).
I thought it should be the very same (according to Q=C*U), but it isn't.
There is always (other mesh, geometry,...) a difference between the abs-values.
Does somebody know why?
Thank you for your help!
Thomas!
Thomas!
3 Replies Last Post 15 nov 2011, 03:58 GMT-5
