Jeff Hiller
COMSOL Employee
6 years ago
18 lug 2019, 16:03 GMT-4
Updated:
6 years ago
18 lug 2019, 15:54 GMT-4
Can you upload your mph file?
Jeff Hiller
6 years ago
19 lug 2019, 00:51 GMT-4
Updated:
6 years ago
19 lug 2019, 00:48 GMT-4
Yes.
Jeff Hiller
COMSOL Employee
6 years ago
19 lug 2019, 08:36 GMT-4
Updated:
6 years ago
19 lug 2019, 08:27 GMT-4
Hi Aashna,
The issue is that before you can subtract a triangle from a rectangle, you need to have a triangle, and in your file there are segments that visually do form a triangle but you have not told the software that you want those three segments turned into a solid triangle. You can do that by converting the three segments into a curve, and then converting the resulting curve into a solid. Then you can select the triangle as the object to subtract from the rectangle.
See the attached file, where I did this for both triangles simulataneously.
PS: If you are starting with COMSOL, I highly recommend binge watching the videos on our Learning Center
Jeff Hiller
Hi Aashna,
PS: If you are starting with COMSOL, I highly recommend binge watching the videos on our [Learning Center](https://www.comsol.com/learning-center)
