Electromagnet design
Posted 31 dic 2009, 15:18 GMT-5 8 Replies
I am trying to simulate an electromagnet, consists of two coils and cores, in order to test different core design and materials. In particular, I would like to test for the magnetic field between the cores, as a function of the current in the coils, taking into account the remanent magnetization in the core (if made from a ferromagnetic material).
Can anyone provide any tips, or point me to a similar model which I can investigate?
Thanks.
I would start with the ACDC manual, the ACDCmodref, and then take a look at the model exchange and model gallery of the web site
I think I need a little more help:)
I am trying to simulate a scenario where the current is flowing in the coils, and then stopped (using one of the smoothed step functions).
Let's consider two coils, and air core. The magnetic field between the coils depends on the current in them. A 2D model of this scenario provides reasonable results ("2 coils, no core.mph").
When I add two soft iron cores to the model, I expect the cores to be magnetized when the current is turned on in the coils, and to remain magnetized when the current in the coils reduces to zero. This remanent magnetization should create a magnetic field between the cores. I cannot simulate that ("2 coils, iron core.mph").
Thanks.
It is not trivial to take into account the hysteresis as the magnetic state of the iron would depend on the magnetization history of the material which could only be obtained through transient analysis.
Look at the different B(H) constitutive equations offered to model magnetized material; you can run simulations sequentially each one having a different B(H) equation representing each part of the magnetization curve and simulate the effect you are looking for.
Hope it helps.
Philippe.
Indeed I hadnt fully understood your problem, I agree with Philippe, your iron M hysteresis is not simulated like that.
Finally you want to remain with a M after having done a B/H trajectory. Perhaps there is a possibility to have two similiar models, one where you calculate the magnetic fields over the iron, due to the current, and with whatever saturation, and the other where you set the M depending on a function related to your previously calculated magnetic field, and then solve the second model, without current.
Now how to define this function so that it represents the remanent magnetisation ? I'm not sure what to say there
Basically, you are saying that comsol cannot natively simulate hysteresis in ferromagnetic materials?
Ivar, thanks for the walk-around. I may try that, although, as you indicated, it is not trivial to write a function that outputs M for a given H, taking into account material properties and geometry.
I will also try to look for similar models, although i couldn't find any in the model exchange.
Please inform me if you have any new idea that can be helpful.
Thank you.
Well I cannot state that COMSOL "CANNOT", but certanly that I havnt tried, nor to think it out, and it does not pop up as a trivial case for me,
If nobody alse out here can answer, then best way then is to try "support" they will certainly give you some interesting clues if its possible, and more definitively state if not possible
Good luck, and pls keep us informed, your problem is interesting indeed
I am trying to simulate an electromagnet with Hiperco 50A alloy which has a non-linear magnetic properties.
From the discussion, I learned that you were talking about similar problem.
Could you please explain, if you were able to solve the problem?
Thanks in advance.
Cheers,
Dhruv
have you studied for example the "ecore_transformer" in the model library ? Or any of the others?
