Help regarding post processing of streamlines
When i plot the streamlines in comsol using streamline positioning as uniform density, the streamlines are appeared as discontinuous lines i.e. there are some breaking sections in the lines ,but streamlines should be continuous lines. How can i solve this problems?
2 Replies Last Post 16 set 2019, 21:45 GMT-4
Posted: 6 years ago 6 ago 2019, 11:28 GMT-4
Updated: 6 years ago 6 ago 2019, 11:27 GMT-4
Use inlet & outlet faces as stremlines faces.
Posted: 5 years ago 16 set 2019, 21:45 GMT-4
Use inlet & outlet faces as stremlines faces. By the way, can COMSOL directly export the specific value of the stream function? If not, what post-processing is needed to get the results?
