Magnestrictive analysis using permanent magnets
Mahdieh Shojaei Baghini Biomedical Engineering
Hi all, I am trying to analyse the behaviour of a magnetostrictive materials with two permanent magnets attached at its ends. Since there is no current flow, I have used the appropriate Physics. After taking help and viewing all the COMSOL documentations on AC/DC models, permanent magnets and non-linear magnetostriction, I am still unable to understand how I should proceed (magnetism isn't my strongest suit).
Should I define additional air domains, or perhaps keep a gap between the magnets and the magnetostrictive material? I don't want to fix any constraints on the magnetostrictive material. The appropriate meshing is there however removed to reduce size of file.
Thank you
Biomedical Engineer
1 Reply Last Post 27 ago 2019, 08:43 GMT-4
Posted: 6 years ago 27 ago 2019, 08:43 GMT-4
I would recommend to take a look at the respective application library model. You find it in the Structural Mechanics department. Magnetostriction is not available in mfnc.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, I would recommend to take a look at the respective application library model. You find it in the Structural Mechanics department. Magnetostriction is not available in mfnc. Cheers Edgar
