Static magnetic field simulation of permanent magnets
I made a two-dimensional permanent magnet simulation. My simulation results only have a picture of magnetic flux density. I want to know if there are other pictures such as magnetic lines. Thank you!
1 Reply Last Post 4 set 2019, 10:47 GMT-4
Posted: 5 years ago 4 set 2019, 10:47 GMT-4
Updated: 5 years ago 4 set 2019, 10:59 GMT-4
Yes, it is most certain possible to generate many other plots than the ones that are created by defalt by the software. This can be done by adding a plot group, and within this new plot group adding plot nodes of whichever type you need (in your can, it sounds like you'll want to add a streamline plot node). Plot groups can include several plot nodes; this allows you to combine several types of information on the same graphics.
In addition to the software's manuals, which you can access through File > Help > Documentation, you will find video tutorials on postprocessing in the COMSOL Learning Center. Some advanced postprocessing techniques are also demonstrated in the Postprocessing and Visalization Handbook, Part 1 and 2.
Jeff Hiller
Hello, Yes, it is most certain possible to generate many other plots than the ones that are created by defalt by the software. This can be done by adding a plot group, and within this new plot group adding plot nodes of whichever type you need (in your can, it sounds like you'll want to add a streamline plot node). Plot groups can include several plot nodes; this allows you to combine several types of information on the same graphics. In addition to the software's manuals, which you can access through File > Help > Documentation, you will find video tutorials on postprocessing in the [COMSOL Learning Center](https://www.comsol.com/learning-center). Some advanced postprocessing techniques are also demonstrated in the [Postprocessing and Visalization Handbook, Part 1 and 2](https://www.comsol.com/documentation). Best regards, Jeff
