Can a 3D "Mapped" mesh have elements of definite proportions (1:5:10)?
Posted 25 nov 2011, 11:41 GMT-5 8 Replies
I have meshed a 3D object using the Mapped mesh. My object is a sum of rectangular elements, and therefore this is most convenient solution (tetrahedron - too many elements, quad doesn't want to mesh 3D, this was easiest) . Since I have a high aspect ratio, I would like to have directional proportions of the element size (I manually adjusted the size of the minimum element but the ratio 1:1:1- ideally I would like to have 1:5:10) - is this option possible for mapped meshing?
error
Singular matrix.
For mesh-case 0 there are 141198 void equations (empty rows in matrix) for the variable mod1.T
at coordinates: (0.0004,0.0381,0.0106667), (0.0004,0.0381,0.0105185), (0.0004,0.0381,0.0103704), (0.0005,0.0381,0.0106667), (0.0005,0.0381,0.0105185), ...
and similarly for the degrees of freedom (empty columns in matrix)
and a warning
Not all domains are meshed
Mesh - mapped - 40k elements, 3D structure, all materials are assigned. What am I doing wrong?
singular matrix means essentially that your BC are not defined in sufficient numer or independently, or that you are missing some material data such that you model is not fully defined, there might be several solutions, and the maths, hence also COMSOL cannot decide for you which one to go for.
My advice, cgo through each physics, step by step and be sure you have given enough BC definitions for each to give an unique results. And check that all materials variables exist.
All my materials are defined sufficiently for the heat-transfer in solids to be solved (cp - heat capacity, rho-density and k-thermal conductivity, where k is the only needed).
I have meshed the model using both mapped and triangular with and wihtout the asigned distribution. -- Same warrning
I have changed all meatrials to one -- Si --Same warrning
I have treated the geometry as both one body and as an assembly (by introducing all the contact pairs and heat continuity in the BC) -- Same warrning
I reduced my BC to only two - Same warrning
So what ever I did, the warrning "not al domains are meshed" was the same, but the error message changed
I believe it's a trivial mistake but I can't see to find it, and the model itself is simple in structure (though a high aspect ratio one).
I'll try redesigning the model from scratch. If the same problem occurs - you'll be hereing from me.
thanks for the reply
not all domains meshed means that you have a domain = solid in 3D or surface in 2D that is not meshed. You have probably meshed the boundaries (surfaces) but not the domains (volumes)
Why not use the default physics induced mesh once, then start to refine manually ?
I have tried with general hysics seting and the simulation works. Thank you, I will be coninuing my work using that setup.
Why in my model I insist on mapped meshing is the following reason - one of my consisiting elements is a 100µm thick tape that covers a microscope cover slip (76.2x25.4x0.13mm). I reduced the calculation by introducing two axes of symetry and yet teh following is the issue (I wont say problem cause it will get done)
finest triangular mesh that does not meet basic convergence criteria (3 elements across smallest gap) - 780 000 elements
a mapped mesh with 7 elements across each of the thin layers -80 000 elements
Since this is my thesis work and research in progress, I'm reluctant to upload the file, but here is an image of the device just to have an idea. If you are interested in teh model and it's problems from a software troubleshouting point of view, I can send it to you.
Again, thank you for your help, the feedback is greatly appreciated
Indeed one of the drawbacks of 3D modelling is the large numebr of elements needed, with a "brute force" approache. So I believe youre stuck to find a more clever way, i.e. 2D simplification, use of symmetry, and/or replacement of thin structures by surfaces with bulk behaviour via some additional physics
Now that the meshing works I get the follwoing
error
Singular matrix.
and a warning
I think you are not meshing the inside of the material, to do so, you can try a sweep mesh (after you meshed the outer faces (at least 1)).
Alternatively, you can use the free tetrahedral and the scale geometry feature to reach the 1:5:10 desired, however, you need to have your domain aligned in the x y z....
Suggested Content
- BLOG Phase Space Distributions and Emittance in 2D Charged Particle Beams
- FORUM why there is no definite integral operator in comsol?
- KNOWLEDGE BASE What Does Degrees of Freedom (DOFs) Mean in COMSOL Multiphysics?
- KNOWLEDGE BASE Failed to respect edge element on geometry edge
- FORUM Definite integral calculation
