Edgar J. Kaiser
Certified Consultant
5 years ago
4 ott 2019, 06:11 GMT-4
Stefanie,
you may consider to run two time dependent study steps in a sequence with adapted time stepping settings. The second step taking the result of the first step as the initial condition.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Stefanie,
Cheers
Edgar
Henrik Sönnerlind
COMSOL Employee
5 years ago
4 ott 2019, 09:27 GMT-4
Updated:
5 years ago
4 ott 2019, 09:32 GMT-4
Maybe you can use Maximum step constraint = Expression and Times to store = Steps taken by solver
As expression you use something related to the expression that triggers the event. A potential problem is that if the solver takes very small time steps somewhere for numerical reasons, you can get a lot of solutions stored.
If the amount of data you generate is a problem, take a look at Store time derivatives, Store reaction forces, and maybe even not storing results for the whole model (Store fields in ouput)
Henrik
Henrik Sönnerlind
COMSOL
Maybe you can use **Maximum step constraint** = **Expression** and **Times to store** = **Steps taken by solver**
As *expression* you use something related to the expression that triggers the event. A potential problem is that if the solver takes very small time steps somewhere for numerical reasons, you can get a lot of solutions stored.
If the amount of data you generate is a problem, take a look at **Store time derivatives**, **Store reaction forces**, and maybe even not storing results for the whole model (**Store fields in ouput**)
Henrik
5 years ago
7 ott 2019, 02:45 GMT-4
Thank you both,
to separate the simulation in multiple steps was not possible, because the time steps respectively the end time do not change during the step.
To use an expression as an maximum step has speeded up the simulation by a factor of 2.5. But the stored time steps is almost the same due to very small time steps when switching between the processes. My main problem here is not the memory space (the models are about 2GB large), but that the evaluation with derived values. This takes more than half an hour due to several integrations over the entire model.
Would it be possible to keep the "Steps taken by solver" setting, but to define a minimum time step to be stored?
Regards
Stefanie
Thank you both,
Regards
Stefanie
Henrik Sönnerlind
COMSOL Employee
5 years ago
7 ott 2019, 14:57 GMT-4
Hi Stefanie,
If you have a reasonable idea about when the event is triggered, you can use Times to store = Specified values and then use two range expressions for the time step, like
range(0, long_step, it_will_soon_happen) range(it_will_soon_happen + short_step, short_step, end_time)
Henrik
Henrik Sönnerlind
COMSOL
Hi Stefanie,
If you have a reasonable idea about when the event is triggered, you can use **Times to store** = **Specified values** and then use two range expressions for the time step, like
Henrik
