Inertia force with an eigenmode-shaped acceleration distribution
Hi all, Is it possibile to insert an inertia force (maybe using the gravity load type) with an acceleration distribution taken from an eigenmode of an eigenfrequency analysis?
The problem is to give a value of the acceleration which is not constant but variable in space (x,y,z). The variation should be equal to a displacement distribution of an eigenmode.
In other words is it possibile to obtain the analytical displacement function of an eigenmode? (knownig that it represents diplacements ratios and not absolute values).
Hope to be sufficiently clear Thank you in advanced, Best regards
2 Replies Last Post 28 ott 2019, 11:02 GMT-4
Posted: 5 years ago 24 ott 2019, 11:17 GMT-4
You can do that using the withsol() operator. In the Gravity node, type something like
withsol('sol1',w,setind(lambda,1))
Here 'sol1' is the tag for your eigenfrequnecy solution. '1' means the first eigenmode.
Henrik
Henrik Sönnerlind
COMSOL
Hi, You can do that using the withsol() operator. In the Gravity node, type something like withsol('sol1',w,setind(lambda,1)) Here 'sol1' is the tag for your eigenfrequnecy solution. '1' means the first eigenmode. Regards, Henrik
Posted: 5 years ago 28 ott 2019, 11:02 GMT-4
Hi Henrik, Thank you very much, it works. Best regards Elia
