20 lug 2009, 18:14 GMT-4
that was also a "feature" I have been missing ever since I started with COMSOL. A "projection" 3D to 2D is rather simple i believe, but no, COMSOL seems not to have that as a standard tool.
My way is to only use SolidWorks for all my geometry (a pity because COMSOL has quite some nice geoemtry features too) as these limitations make life really difficult only remaining in COMSOL. Now SolidWorks and GibbsCAM (our CAM softweare) but is not the best either, because it cannot generate 2D dxf files (they are 3D with i.e. Z=0 and this COMSOL can neiter not read in), so I often edit the files by hand !
You have to play with the import "options" and I use often IGES, but still certain features do not pass.
I will suggest that you and other out there report this systematically to COMSOL support, then they might put this higher on their priority list.
By the way, by thurning on the correct view (there is a button for this and a menu, Im off site and has no access to COMSOL just now) you can get the image of the lines on the 2D ViewPlane, this helps to overdraw quicker the geometry
27 mar 2012, 05:02 GMT-4
Some years have passed now. Have anyone found a simple (automatic) way of projecting to 2d from the solidworks livelink?
With Best Regards,
Magnus
With Best Regards,
Magnus
8 years ago
23 nov 2016, 10:07 GMT-5
See the blog
"creating-2d-models-from-3d-geometries-in-comsol-multiphysics"
https://www.comsol.com/blogs/creating-2d-models-from-3d-geometries-in-comsol-multiphysics/
-DW
