Henrik Sönnerlind
COMSOL Employee
5 years ago
28 ott 2019, 06:22 GMT-4
Updated:
5 years ago
28 ott 2019, 02:22 GMT-4
What you are looking for is probably the Nonlinear Elastic Material with the input option Uniaxial data.
Henrik
Henrik Sönnerlind
COMSOL
What you are looking for is probably the **Nonlinear Elastic Material** with the input option **Uniaxial data**.
Henrik
5 years ago
28 ott 2019, 07:52 GMT-4
Hi Henric,
thank you so much for your reply.
I tried to use it, but the fact is that I have a lot of samples tested, each with different behaviour, so I don't understand how I can define a large number of curves which describe the stress-strain relationship.
This is my doubt.
Could you help me?
Thanking you in advance,
BR
Maria
Hi Henric,
This is my doubt.
Could you help me?
BR
Maria
Henrik Sönnerlind
COMSOL Employee
5 years ago
29 ott 2019, 03:55 GMT-4
Updated:
5 years ago
28 ott 2019, 23:55 GMT-4
Hi Maria,
I do not really understand the question here. Are you interested in some kind of averaging of the measured curves, or do you want to make several analyses, using different curves?
Henrik
Henrik Sönnerlind
COMSOL
Hi Maria,
Henrik
5 years ago
29 ott 2019, 06:10 GMT-4
Hi Enric,
the fact is that I have tested several samples of the same material, having different mechanical properties. In particular, during the compression test, they show different behaviour, so the curve stress-strain of the first sample, for example, changes its slope at one specific value of strain, while the curve corresponding to another sample changes its slope at different strain value.
My issue derives from these different behaviour. I'm interested of averaging of the measured curves, but it seems difficult to do this.
I would like to ask you if I could define a Piecewise Function where Young Modulus is defined with refers to strain, so that i could define different strain intervals where Young Modulus assumes different values.
Then, under the node "Linear Elastic Material", I could use this function in order to define the mechanical properties of the material.
Is it a good approach?
BR
Maria
Hi Enric,
BR
Maria
Edgar J. Kaiser
Certified Consultant
5 years ago
29 ott 2019, 06:25 GMT-4
Hi Maria,
looking at your question from a physical point of view, I don't think averaging material properties with large variations is a good approach.
I would rather think that you need to run the simulations using different material curves in order to see which way they affect the simulation result you are interested in.
This may be particularly critical as the model seems to be nonlinear.
My two cents. Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Maria,
Edgar
5 years ago
29 ott 2019, 06:52 GMT-4
Hi Edgar,
thank you for your reply.
I agree with you, but I cannot compute several simulations. For my work, I need to find a single simulation that can accurately describe the material behaviour.
Now I'm trying to define Young modulus E wrt strain (solid.eZZ).
Do you think this could be a valid approach?
BR
Maria
Hi Edgar,
BR
Maria
Edgar J. Kaiser
5 years ago
29 ott 2019, 07:05 GMT-4
Maria,
the model may then be correct for this specific material curve. However, with just one simulation you won't be able to validate the model for variations in the material behavior and this seems to be a critical part in your task.
So, no, it is probably not a valid approach.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Maria,
Cheers
Edgar
