rectangular input
Hyun Kwon engineering
I would like to add a concentration only for a predetermined time, i.e. rectangular input instead of step input. How should I type this in the COMSOL as a expression? Will it take anything like this?
C0*( u(t)-u(t-2))
1 Reply Last Post 20 lug 2009, 18:25 GMT-4
Posted: 2 decades ago 20 lug 2009, 18:25 GMT-4
why u(t) ? what do you mean by that ?
u for me has a default dimension of [m] in COMSOL, check carefully your dimensions.
But you could use a C0*(t>0.5)*(t<1), this would make a step function between 0.5 and 1.
Now, do not forget that this step function does not have any defined derivative at the discontinuities, so your solver will probably not manage to pass the steps !
The are the Heaviside functions (fldc1hs, flc2hs, flsmhs, flsmsign ...) to make smooter steps with contiuous derivatives, they work mostly better, see the doc .
By the there was another discussion about steps functions about a month ago
Hi why u(t) ? what do you mean by that ? u for me has a default dimension of [m] in COMSOL, check carefully your dimensions. But you could use a C0*(t>0.5)*(t
