14 dic 2011, 09:45 GMT-5
the easiest is probably to intersect the scare with a filleted conical shape, much as a pencil tip going from a hexagon (and not a square but that is the same) via a cone then to a cylinder with perhaps a fillet junction, this should work even if the cylinder is larger than the rectangle or vice versa, but it assumes you have a common axis
Hope it's clear ;)
Hope it's clear ;)
14 dic 2011, 10:20 GMT-5
Hi Ivar,
I tried somethings but I didn't manage to complete it.
A cone could be set up on the cilinder.
But how can I change the upper surface of the cone (I tried intersection but this must be done in a workplane? how can I get the two surfaces in the same workplane?)
I only capable of having a round cone.
Can I extrude the square surface into a round surface over a certain distance?
Hi Ivar,
Jeff Hiller
COMSOL Employee
9 years ago
4 dic 2015, 10:31 GMT-5
The Design Module (which did not exist when this thread was started) includes, among other things, two capabilities that makes creating this geometry a cinch:
- 3D filleting
- Lofting
I am attaching a screenshot illustrating those capabilities on your geometry.
- 3D filleting
- Lofting
