Translating comsol version 5.4 to 5.3
Fernando J. Pena Cantu
Hi my University utilises two different versions for comsol 5.4 and 5.3. However they only have Matlab live link with version 5.3 but I have done all my work with 5.4. Is they a way to translate a file that was made in 5.4 into 5.3 version.
Thanks.
3 Replies Last Post 3 gen 2020, 03:35 GMT-5
Posted: 5 years ago 2 gen 2020, 10:34 GMT-5
Hello Fernando,
If your file created with version 5.4 only uses features that existed in version 5.3, yes. This thread should help.
Jeff Hiller
Hello Fernando, If your file created with version 5.4 only uses features that existed in version 5.3, yes. [This thread](https://www.comsol.com/forum/thread/163681/save-a-model-as-older-version?last=2018-02-07T12:01:36Z) should help. Best regards, Jeff
Posted: 5 years ago 2 gen 2020, 10:42 GMT-5
It's interesting to know such a possibility. Thanks!
According to the thread, one should save the .mph model file as a .java file and then compile it with a lower version compiler. But could a lower version .mph file be recovered from the .java file?
ZHANG, Pu
School of Physics,
Huazhong University of Science and Technology
It's interesting to know such a possibility. Thanks! According to the thread, one should save the .mph model file as a .java file and then compile it with a lower version compiler. But could a lower version .mph file be recovered from the .java file?
Posted: 5 years ago 3 gen 2020, 03:35 GMT-5
Hi Pu,
The compilation process as such should in principle be version independent. It is just a matter of getting a .class file from a .java file.
When you later run the .class file from a certain COMSOL Multiphysics version, and then save the model, the .mph file gets its version number. In principle, you could thus create several .mph file versions from a single .class file.
Henrik
Henrik Sönnerlind
COMSOL
Hi Pu, The compilation process as such should in principle be version independent. It is just a matter of getting a .class file from a .java file. When you later run the .class file from a certain COMSOL Multiphysics version, and then save the model, the .mph file gets its version number. In principle, you could thus create several .mph file versions from a single .class file. Regards, Henrik
