Time varying load in transient PDE
Hi Everybody,
I would like to use the sinusoidal time varying load: sin(pi*t/6) in the simulation for transient PDE.
How to use the time in defining the load?
Thanks in advance.
Rakesh
2 Replies Last Post 7 gen 2010, 19:27 GMT-5
Posted: 2 decades ago 7 gen 2010, 00:44 GMT-5
normally for a transient you set up your load as F=F0*sin(2*pi*f), but mostly when you work with sinus load you shoul use the harmonic mode, where one uses the Fourier space
Hi normally for a transient you set up your load as F=F0*sin(2*pi*f), but mostly when you work with sinus load you shoul use the harmonic mode, where one uses the Fourier space Good luck Ivar
Posted: 2 decades ago 7 gen 2010, 19:27 GMT-5
Ivar,
I am using PDE general form to model the system. How to use the harmonic mode in general form?
Is there any way to use the solution time 't' in the equation ?
Rakesh
Ivar, I am using PDE general form to model the system. How to use the harmonic mode in general form? Is there any way to use the solution time 't' in the equation ? Thanks, Rakesh
