Edgar J. Kaiser
Certified Consultant
5 years ago
11 gen 2020, 10:16 GMT-5
Andreas,
are the boundary conditions at the end faces equivalent in 2D and 3D?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Andreas,
Cheers
Edgar
5 years ago
11 gen 2020, 12:45 GMT-5
In 2D you are modeling a medium infinitely thick in the z direction. Any volume-dependent quantity is calculated for a 1 m section of the infinitely thick medium. There is no heat flux in the z direction.
In 3D there can be heat loss (gain) on the front and back (+z and -z) faces. The problems are not equivalent.
Edgar J. Kaiser
5 years ago
11 gen 2020, 13:21 GMT-5
Thermal insulation at the front and back face can make 3D equivalent to 2D if the other BC are chosen appropriately.
Edgar J. Kaiser
www.emphys.com
5 years ago
11 gen 2020, 14:10 GMT-5
Yes there is thermal insulation at the front and back face.
So assuming all the boundary conditions are the same, there should be exactly the same result? Although I think the boundary conditions are equal, there probably is a mistake in there somewhere.
Thanks for your help.
