Electrical Circuit in Electrostatic Simulation
Hello!
Is it possible to have a electrical circuit problem connected with an electrostatics problem?
For example I want to connect a capacitor with a certain value to my electrostatics simulation.
If yes, how do I connect them, when my Terminal BC is defined in the electrostatics?
Thank you for your help...
Thomas
7 Replies Last Post 7 lug 2013, 05:21 GMT-4
Posted: 1 decade ago 21 dic 2011, 11:50 GMT-5
I got the same problem, I saw a paper mentioned using extrusion coupling and assmblies to do that.
learn COMSOL, like COMSOL
I got the same problem, I saw a paper mentioned using extrusion coupling and assmblies to do that. -- learn COMSOL, like COMSOL
Posted: 1 decade ago 11 apr 2012, 14:22 GMT-4
Hi Thomas,
Did you find a solution to the problem that you mentioned in this post. I am facing the same problem. I have a pressure sensor model which I want to couple to a front end circuit. Is there any way I could do that?
I appreciate your help.
Bhavin
Hi Thomas, Did you find a solution to the problem that you mentioned in this post. I am facing the same problem. I have a pressure sensor model which I want to couple to a front end circuit. Is there any way I could do that? I appreciate your help. Bhavin
Posted: 1 decade ago 12 apr 2012, 01:06 GMT-4
Hello!
I am sorry, but I could not solve this problem (with comsol).
Perhaps anyone else?
Thomas
Hello! I am sorry, but I could not solve this problem (with comsol). Perhaps anyone else? Thomas
Posted: 1 decade ago 12 apr 2012, 02:28 GMT-4
is it something like this you want to do ? I'm using the initial value on the circuit capacitor to discharge the capa into the COMSOL model
Hi is it something like this you want to do ? I'm using the initial value on the circuit capacitor to discharge the capa into the COMSOL model -- Good luck Ivar
Posted: 1 decade ago 13 apr 2012, 03:42 GMT-4
Hello!
Thank you for the fast answer. It is similar to what I was lookin for, but I don't understand it completley.
What happens with the init-value of the capa?
The simulation acts like one would switch on 10V even if it says 10V init value?
For example, how do I get a real init value for the capa?
Thanks again for your answers...
Thomas!
Hello! Thank you for the fast answer. It is similar to what I was lookin for, but I don't understand it completley. What happens with the init-value of the capa? The simulation acts like one would switch on 10V even if it says 10V init value? For example, how do I get a real init value for the capa? Thanks again for your answers... Thomas!
Posted: 1 decade ago 13 apr 2012, 11:37 GMT-4
my capa is very large compared to the one in the model, if you put a one pf capa the voltage should drop, test it out ;)
Hi my capa is very large compared to the one in the model, if you put a one pf capa the voltage should drop, test it out ;) -- Good luck Ivar
Posted: 1 decade ago 7 lug 2013, 05:21 GMT-4
Hello everybody.
I have a quite similar problem, I would like to charge a capacitor with a current source of 25mA and compliance of 70V. So when the capa is charged, the voltage drops to 0. How can I simulate this using the CIR module?
Have a nice day!
Hello everybody. I have a quite similar problem, I would like to charge a capacitor with a current source of 25mA and compliance of 70V. So when the capa is charged, the voltage drops to 0. How can I simulate this using the CIR module? Have a nice day!
