23 dic 2011, 04:07 GMT-5
if you define a integration coupling operator on a recangle (domain in 2D) you are integrating over the domain of your operand *dx*dy, you need to define it over a line/edge along x or y or "r" to get a 1 dimensional operator
23 dic 2011, 08:24 GMT-5
Hi Ivar,
I really have to integrate over that rectangle. The problem is the convolution with the 2D gaussian function. Right now Comsol is calculating the result everywhere on that rectangle (and this takes too long), but I only need the results on a line in the middle of the rectangle.
(Replacing dest(y) with -0.5[um] lets Comsol calculate the right thing but there is no gain in performance since it is still calculated for every point on that rectangle the result is however independant of the y cordinate of course).
Happy holidays
Robert
Hi Ivar,
Happy holidays
Robert
23 dic 2011, 08:29 GMT-5
Application Error
Sorry, the application encountered an unexpected problem.
The application encountered an unexpected problem, and were not able to process your request. An error report has been generated and sent to us. Should this problem persist, please don't hesitate to contact us at webmaster@comsol.com for personal assistance.
Application Error
application error but posted
23 dic 2011, 09:15 GMT-5
can you apply it to a data set - cut line ? or add an interior boundary ?
(many App error today from my side too, COMSOL must have some disk or network issues to solve, nice for the Xmas time ;)
30 dic 2011, 11:51 GMT-5
putting a dataset cutline is the way it is done in the file right now.
However the data for the entire 2d area is still calculated - so Comsol is doing some bonus work which is time consuming.
I can not imagine how an interior boundary can solve the problem. The integration coupling operator really needs to be defined on the entire area. But the calculated datapoints need only to be on a line.
The way I think it can be done is by solving the problem on a 2nd 1D model where just a line is defined. Then I need to access the solution of the 2D model and the integration coupling operator of the first model but Comsol is then infact solving the problem on the line.
I have seen an example
www.comsol.com/showroom/documentation/model/699/
and perhaps I can connect different models somewhat like there.
Bye
Robert
http://www.comsol.com/showroom/documentation/model/699/
Bye
Robert
1 gen 2012, 15:34 GMT-5
I do have some problems to follow you, as I'm not fully understanding your model, but I agree your "u" needs to be calculated on the 2D domain, the way you define it, but you want to evaluate "u" only along a line. I'm not sure if there is any other way around
Now for your model, the time needed does not seem significant for me, OK if you consider another mdel with 100x higher mesh density it can be an issue.
By the way be careful with the variable naming, most single lettres are already used by COMSOL, "u" by default is used as dependent vairable in solid, so you can get strange results depending on how you mix a few physics that way
Form your original model I get factor 2 difference between the two solution methods, otherwise they look very similar
